saluki_engineer
- Colorado
I am doing a plant layout that requires a new run of underground utility to a transformer outside the new building. The new utility will need to run parallel to an electrical duct bank containing plant power and communication lines. The contractor has asked me to specify the minimum distance to maintain between the two to minimize EMI.
I have directed them to maintain as much distance as possible for the parallel runs and make sure they intersect at approximately 90 degrees, but I would feel better if someone could point me to a standard that specifies this, so I could give them a minimum distance. I don't see this mentioned in the NEC or the utility's installation requirements and my google search hasn't given me anything useful. Any help would be much appreciated.
