J
jonny1982
Guest
Is it acceptable to run the voltage input for an emon dmon off the same breaker that the emon dmon is monitoring if it is a high amperage breaker?
For instance, lets say I am monitoring a 100 amp breaker with an emon dmon. The terminals for the input voltage of an emon dmon are rated for max #10 wire. The breaker I am monitoring is a 100 amp breaker. Can I run #10's off the 100 amp breaker to the input voltage of the emon dmon if it is less than 10 feet away? Does it fall under the 10' tap rule?
I know the ideal would be to come off a 20 amp breaker of the same panel, but if the panel is maxed out, is this acceptable knowing that the emon dmon will only draw so much amperage?
Thanks
Thanks
