joe tedesco
- Boston, Massachusetts
Question:
1. How does the following OSHA rule apply to a Home Inspector?
2. Should this rule be applied to a one-person shop?
OSHA Part 1910.132(d) (1) ? ?The employer shall assess the workplace to determine if hazards are present, or are likely to be present, which necessitate the use of personal protective equipment (PPE). If such hazards are present, or likely to be present, the employer shall:?
OSHA Part 1910.132(d) (1) (i) ? ?Select, and have each affected employee use, the types of PPE that will protect the affected employee from the hazards identified in the hazard assessment;?
OSHA Part 1910.132(d) (2) ? ?The employer shall verify that the required workplace hazard assessment has been performed through a written certification that identifies the workplace evaluated; the person certifying that the evaluation has been performed; the date(s) of the hazard assessment; and, which identifies the document as a certification of hazard assessment.?
OSHA Part 1910.335(a) (1) (i) ? ?Employees working in areas where there are potential electrical hazards shall be provided with, and shall use, electrical protective equipment that is appropriate for the specific parts of the body to be protected and for the work to be performed.?
