EMT as EGC
Therealcrt
Kansas City
If the previous install used the EMT as an EGC for a 225a panel do we need to have certain fittings that are code compliant when using EMT as EGC? We relocated the panel and used the same feeders and rerouted the conduit. Are set screw ok or compression only? They had compression fittings installed originally
All listed EMT fittings are approved for grounding so you can use any type that you want including set screw.
