I used these for a diy project in my home. So very limited experience.
My experience was almost the opposite of post #6. The fittings were too snug and I couldn't be sure that they had seated correctly.
The fittings have a shark bite toothed ring and then a straight sleeve section. I found that the EMT was binding in the sleeve section rather than fully seating.
My guess is that I was dealing in the opposite end of the tolerance range,
@ActionDave probably had EMT on the small end of the tolerance range so the fittings were floppy, I had EMT on the large end of the range so it didn't fit well.
Or perhaps I flattened the EMT a bit when cutting it.
My recommendation is that if these fittings are used, that a procedure be required to verify that the EMT is fully seated and properly gripped.
Jon
