D domnic Senior Member Occupation Electrical Contractor Aug 10, 2008 #1 can i use emt setscrews fittings under a carport all emt is covered by roof.
Jim W in Tampa Senior Member Location Tampa Florida Aug 10, 2008 #2 Yes as it is only a damp location
C chevyx92 Senior Member Location VA BCH, VA Aug 10, 2008 #3 domnic said: can i use emt setscrews fittings under a carport all emt is covered by roof. Click to expand... Are they listed for a damp location?
I ItsHot Senior Member Location A little piece of heaven! Aug 10, 2008 #4 sure sure Sure you can! But I would use compression fittings!!
mdshunk Senior Member Location Right here. Aug 10, 2008 #5 I sure wouldn't hesitate to. By the way, check prices. Steel set screw fittings have been cheaper than cast lately, for some reason.
Jim W in Tampa Senior Member Location Tampa Florida Aug 10, 2008 #6 set screws are exsposed all the time.The wire in them we will assume is thhn/thwn.
