Alwayslearningelec
- NJ
- Estimator
If you had to run a lot of 1-1/4"( any size for that matter) EMT stub-up from wall data outlet to right above hung ceiling would and the distance was only 7', even with the hook into the ceiling would you cut a 10' stick of conduit to length or use use the 10' stick? THink it might take more time to cut/ream rather than just installing the 10' stick. Hey I'm not even sure maybe a 10' stick is required to get you from outlet to above hung ceiling.
