EMT to FMC fitting
conmgt
2 Phase Philly
Hi,
I need to go from 1 1/4" EMT to 1 1/4" FMC and can't seem to find a fitting above 1" that does that. Has anyone seen one?
I guess I could do an EMT connector to a rigid coupling to a FMC fitting but that seems a little silly. Is there such a thing as a female EMT or FMC connector?
Some woukd argue that the connector to coupling to connector is not code compliant.
Given the code dilemma I thought that some manufacturers were actually making larger transition fittings.
Hi,
EMT connector to a rigid coupling to a FMC fitting, I think that is the only option you unless you want to install a Jbox in between.
Sometimes, the UL listings do not make any sense, except they are to make cents for the manufacturer.
