cyado1607 said:I believe it is faster and cheaper to use an EMT to Sealtight Connector. These are listed for the application and you will not have an inspector second guess the installation.
infinity said:So what do you do above 1"?
bnewport said:I recently took a code update class and I remember something being said about a code change, and it having to be a listed fitting, and that a connector/coupling/connector was not listed for the application.
TOOL_5150 said:Here we go again - a coupling is listed to couple, a connector is listed to connect. as long as each fitting is used for what it is listed for, then I see no problem with using more than 1 fitting to transition from one wireway to another.
~Matt
IMO it's fine with me....TOOL_5150 said:Here we go again - a coupling is listed to couple, a connector is listed to connect. as long as each fitting is used for what it is listed for, then I see no problem with using more than 1 fitting to transition from one wireway to another.
~Matt
iwire said:Some will surely say hit a box, but I will not be one of them.![]()
paul said:But you WILL say that one cannot stub up a uffer. :grin:
iwire said:I also like Wendy's double Cheeseburgers I just don't see how any of these things are related. :grin:
Mmmm, Wendy's! Double cheese, extra cheese, everything, no pickles, no onions, add bacon. Perfecto!iwire said:I also like Wendy's double Cheeseburgers
