mollydodger
Does anyone know of a company that makes a LISTED fitting to connect EMT DIRECTLY to LMC or LNMC in LARGER THAN 3/4 trade size???? TIA
mollydodger said:Does anyone know of a company that makes a LISTED fitting to connect EMT DIRECTLY to LMC or LNMC in LARGER THAN 3/4 trade size???? TIA![]()
Yep, that's a list, all right. :grin:iwire said:Sure a listed EMT connector, a listed RMC coupling and a listed LFMC connector.
Nothing 'not listed' about it.
Pierre C Belarge said:Is a listed EMT connector listed to be installed with a listed RMC coupling?
Is a listed LFMC connector listed to be installed with a listed RMC coupling?
iwire said:IMO no, not specifically. Just like a wire nut is not specifically listed to connect a blue conductor to red conductor.
A coupling is listed (I imagine) to be used as a coupling, connectors are listed for connecting.
Is the threaded end of an EMT connector 'listed' to be connected to any specific item?
Is an RMC coupling listed to couple any specific item?
You already saw OZ-Gedney says chase nipples can be used with RMC couplings.
iwire said:IMO no, not specifically. ....
M. D. said:I would love to see that it was tested as a low impedance fault path ,.... they can claim it can be used to
A 1/2", setscrew fitting with locknut (zinc, aluminum, steel, or malleable) must meet the following key requirements:
LJSMITH1 said:For a cable or conduit fitting to be UL listed, it needs to pass the rigors of testing outlined in UL514B. What some don't realize is that just because a fitting may seem secure in its connection, it still may not meet the specifications in UL514B for that particular use.
