Alwayslearningelec
- NJ
- Estimator
Anyone ever use 4" EMT with integral coupling? Thoughts on this, if used, would be appreciated. Thank you.
Thanks Why would bends make a difference?Yes I've used them. My recommendation would be for straight pipe like vertical risers they're okay. For anything else like runs with bends I would prefer separate external couplings.
You need to think about tightening the couplings after the conduit is bent. You need to be able to access the screws.Thanks Why would bends make a difference?
I'm not following not being able to access the screws after it's bent? How would that happen? What type of bend would not allow access to screws? What psotion would it be in?You need to think about tightening the couplings after the conduit is bent. You need to be able to access the screws.
Also note bell pipe if installed with the bell facing down in a riser/vertical installation can be fairly water/concrete proof. This can provide a little extra piece of mind when brickies are near our work.
You really need to spend two weeks working with a crew as summer help !I'm not following not being able to access the screws after it's bent? How would that happen? What type of bend would not allow access to screws? What psotion would it be in?
