jorgeaviles70
- New york
- Electrician
Can you use empty EMT as supports for lighting ? I know 358.15 (5) said you can’t not but the pipe it not a raice way
Thank you for the replay .. There is an article for that thank youyes, it is just a length of round steel tubing, it is not a raceway
While my son was in middle school I took a bundle of 1/2" EMT to make a many sided dome. Cut 10' lengths into thirds ( 3' 4" ) and had kids drill holes in ends and use 3/16 stove bolts to assemble them. Had 4 or 5 kids on sides at the same time.I once used 3/4 EMT to make a geodesic dome. The pieces were a bit shy of 5 feet long. You could hang hammocks from the vertices. No wires were installed in the EMT.
There is a Home Depot in North Carolina where they used 1/2” EMT to suspend 8’ flouresnts. Weight of the fixtures bowed the EMT badly! (Not us, another contractor)Always used 3/4" EMT to hang luminaries. Usually do not carry or stock.much 1/2" EMT. Forget what # jack chain supply house would give us when we picked up boxes of them. Think #12 jack chain is good for 25 to 28 # working load.
Yes, this is where length mattersThere is a Home Depot in North Carolina where they used 1/2” EMT to suspend 8’ flouresnts. Weight of the fixtures bowed the EMT badly! (Not us, another contractor)
Years ago most ceiling bar joist were fairly close together but have doubled or more in spacing. In that case might have to use 3/4" heavy wall conduit. Some businesses owners will get a free lightning layout when purchasing luminaries from supply houses . Problem with that they do not take in account huge HVAC duct work, double runs of overhead conveyors etc. Had to go back after installing 250 watt luminares and hang 8' two tube fluorescent fixtures to kill shadows.There is a Home Depot in North Carolina where they used 1/2” EMT to suspend 8’ flouresnts. Weight of the fixtures bowed the EMT badly! (Not us, another contractor)
