enclose knob and tube wire
Cjx3
Tacoma
have a client asking if there is a safe way to put conduit or split wire loom around knob and tube wiring? pvc split duct? I haven't heard of anyone doing that but thought it might be doable. thanks for any help
Of course I don't know the entire circumstance. Sometimes the accommodation is worse than a real fix. It would seem if you can put a split duct around it then it shouldn't be more work to just replace it??
also check homeowners insurance -- some dont allow any changes to K&T other than replacement, some will not even insure a house with K&T (e.g state farm in WA)
I would say to the home owner 'because?" I so no need to do this unless the insulation is bad, then replacement is the proper answer. I've left plenty of properly working K&T in homes in Richmond. More rodent proof than NM! ;)
I agree. Probably long pieces that are bare.
I had one like that. HVAC guy was getting lit up when he tried crawling across trunk line in attic.
I was asked to ghetto-fy it
Nope. All new. No other options from me.
But I've seen a lot of it in good shape, too
I would never try to put metallic conduit or EMT around old knob and tube wire.
A proper knob and tube installation will be quite resistant to problems caused by insulation breakdown..
If you are worried about rodent damage, it may be code compliant to use something ilke this over individual wires.
It may prevent cat damage but not sure about rodents.
thanks everyone. I did crawl around and inspect the attic. the splices and insulation are actually quite intact for the age of the house. at most I was thinking of just taping up the splices again to east their mind...
rewire of the attic would be way more work I think than just running pvc split duct or a wire loom of some sort. not to mention far cheaper. again its more about home inspectors causing more concern than truly necessary. love/hate relationship with those guys.
I was worried about potential heat. its not covered in insulation though. so thought it would be acceptable.
Most K/T I have seen was pretty far gone already. Thump a wire and watch insulation crumble off. You may be able to use split flex around it but this is a poor band aid. Not worth doing and if something goes wrong, guess who gets the blame.
I saw a very few houses where it was in good shape but they were the exception for sure. Insulation hadn't covered it, loads were moderate. These were nicer old homes that had more circuits than normal, so not much overloading. Work done very well.
Be a "Ghost Buster" get rid of the K&T.
Had a call that started out with kitchen light repair that ended in mostly a rewire. Lights on a K&T with burnt timber around the wire penetration and no boxes, seems to have have been a normal installation method, at least in this house. HO had also complained about ghosts.
The home inspector said the K&T was not in use but was dead wrong, it was live throught the home and badly modified. Found it throughout the house multiple taps to 75% of all the outlets both receptacle and lighting.
Just by chance was using a ticker like is commonly used to determine hot wire and just standing in the middle of room it was going off just as if I was on a hot wire, never ever seen that before.
Shut down first one circuit and lost nearly half the house, no visual sign at panel box of the K&T but found taps onto some of the K&T back into a corner of basement found a lot of bared K&T conductors crossing the basement and some resting onto the heat ducts (at least it was the neutral, wink wink) but not the circuit that shut down the half house. Then found an old fuse box in attic that evidently was the original service panel as it still had the original 3 wire that would come thru the wall. Somewhere it had been tapped onto with NM to provide the power to half the house. Never did find that splice point, but likely an old splice as the circuit left the panel as the old rag wire. Also someone used "blow-in" insulation and encapsulated all the K&T, in the wall and ceiling.
Oh by the way when shutting down of the K&T and getting rid of it, the HO reports "ghosts" also left. (Maybe got a new sign for the side of the truck?)
