I design controls for custom equipment where typically 480vac is brought into the enclosure and then stepped down from there to power items in the enclosure. We feed the 480vac through a panel mounted disconnect with the disconnect handle located on the outside of the enclosure. If the disconnect is "on" the disconnect handle has to be defeated in order to open the enclosure. The job I am working on now we are bringing in 120vac into the enclosure. Does the disconnect have to be done the same way at this voltage level?
