D deerhunter98 Member Apr 29, 2004 #1 Is there a code that states that a starter must have a certain size enclosure for heat dissipation?
B bphgravity Senior Member Location Florida Apr 29, 2004 #2 Re: Enclosure Size I do not believe this is specified by the NEC, there will be a UL/NEMA and manufacturers instructions r
D deerhunter98 Member Apr 30, 2004 #3 Re: Enclosure Size You are correct. After speaking with several people, the only thing that the NEC Code is concerned with is bend radius. I need a copy of: Sect 312, Table 312, 6 A & B sent to me. Can someone email me a copy of this to bjmays@bpspump.com. Thanks
