I understand the need to ground conductive sub-panels & acess panels that contain electrical equipment. But why is it required to ground similair panels that pianted. I often see painted panels with a small masked area for bonding the panel to the ground bus. The purpose of the ground is to provide a low impedance path to operate the over current or protective device. However, if a non conductice surface, like paint, comes in contact with a live wire, the grounding path would not be completed. What am I not understanding?
Thanx
Thanx
