End Of Course Test Questions
Some State End Of Course questions for Electrical Technology that are questionable?
A current transformer should never be operated when:
1-The primary is disconnected
2-The secondary is disconnected
3-the primary is connected
4-The secondary is connected
When power is lost, high-intensity discharge lighting goes through a period before coming back on. This period is called:
1-Pre-heat period
2-Heating period
3-Cooling period
4-Standby period
A transformer is to be removed. Once the transformer has been isolated from all power sources, you should:
1-Disconnect the primaru first
2-Disconnect the secondary first
3-Ground out the primary and secondary
4-Loosen the taps
A typical use for a potential type relay in a control circuit would be to:
1-Aid the starting of a 3 phase motor
2-Aid the starting of a dc motor
3-Aid the starting of a synchronous motor
4-Aid the starting of a capacitor-start motor
An ac generator has a separate dc generator connected to the same shaft as the rotating field. This dc generator is called:
1-A shunt dc generator
2-An excitoe
3-A twin generator
4-A rectifyer
Please let me know which, if any response is correct for each question.
iwire
Massachusetts
2
1-Pre-heat period
2-Heating period
3-Cooling period
4-Standby period
3
4-Loosen the taps
1
No idea
2-An excitoe
3-A twin generator
4-A rectifyer
1
