FYI,
I just installed some electronics in a State building with services from Comcast. The product went up in smoke!. I found 55VAC on the center conductor of the coax. Seems that Comcast field techician neglected to remove the power shunt from the amplifier feeding the building.
Also I was trouble shooting signal related probems with a home run cable installation at a High School. I removed the coax from on classroom and instantly receive a healthy shock. My volt meter measured 75VAC to the coax shield and rack.
I found that the electronics connected to the coax in the classroom went through 3 daisy chained outlet strips. The voltage between neutral and ground was 75VAC. Upon further investigation the outlet strip plugged into the wall had the ground broken off and the plug was rotated around since the plug wasn't polarized.
Think safety
Be safe,
satman
Think safety
Be safe,
satman
