Scenario
Qualified electrician called to troubleshoot a MCC Bucket within an MCC controlling a Process. Per 70E he puts on proper Arc Flash PPE, turns the disconnect
bucket handle to the "OFF" position, opens the door and uses a DMM to determine that the disconnect within this bucket is in the "OPEN" position. Verifying that there is no voltage on the components of the bucket. Questions #1 Can the Electrician take the ARC Flash PPE off at this point, is this a confirmed "ESWC".
Question #2 per the 70E is an "Energized Electrical Work Permit" required before performing the work mentioned above?
