When one comes in contact with an energized conductor but doesn't complete the circuit back to the source, why don't we feel the sudden change of potential?
Thanks
The reason why you don't feel the change is because your body is not sensitive enough to detect it. Any change in potential (voltage) requires a transfer of electrons. For low voltages, this transfer of electrons is relatively trivial and not noticeable, but it still happens.
I know you were around back when this "helicopter" example came up a few years ago, so you can go back and read some of that discussion. (I don't feel like doing a repeat performance--although it was fun at the time.)
We are constantly experiencing different potentials on our bodies every day, simply because the absolute voltage of our planet is constantly changing as energy is absorbed and lost. We (our planet) are like a bird on a wire. Our potential is constantly changing, and we absorb and lose electrons in the process, but the rate of change is trivial compared to when we are
not isolated from a different voltage reference (i.e. current flow).
You're not going to "feel" this charge/discharge when the difference is only a few hundred volts, but you will feel it when the charge/discharge is in the hundreds of thousands of volts. That's why the helicopter arcs, not because of capacitive coupling to the source.
You don't feel the build up of charge in your body as you walk across the carpet, but you do feel it when you contact a voltage potential significant enough to result in a rapid discharge.
