Enforcement angel
mikeames
Gaithersburg MD
Teacher - Master Electrician - 2017 NEC
One persons logic is not anothers.
The code has to do what it has to do, the NFPA is not concerned with the enforcment angle.
As far preventing what a hack and a homeowner may do ....
Make something idiot proof and someone will make a better idiot. :grin:
I stole this from a previous thread because it did not want it to run on.
I agree with this however would it not be a good idea for the NFPA to give at least a little thought since fire prevention and safety are their goals?
I am refering to the example in a previous thread http://forums.mikeholt.com/showthread.php?t=118464 where a bathroom was beign remodeled. A receptical had to be added however the existing circuit was only 15 amps. So the entire circuti has to be redone even though a new circuit is not needed just and additional recep on the existing. The issues is the professional electrician has to follow the code which will cast more while a non professional can do a safe job costing much less. If the cost difference is $60 vs $1000, and both are equally safe, wheres the incentive for the home owner to hire a licensed professional?
Even home owners know that electricity in the wrong hands can cause fire. The incentive
is sleeping 2 doors down the hallway.
Mike what is your suggestion?
Who should get to decide if something is 'equally safe'?
Should the NEC have a section called 'If it is tough, costly or otherwise bothersome you don't have to do it'?
Personnly I see no real problem with adding the 15 amp circuit, but I do not see that the NEC allows it so the inspector should not allow it either.
I really do not see an easy answer.
Le's say that a contractor bid the job to just add 3' of #14 and move the outlet. I come out and write a correction notice that it needs to be a 20 amp circuit (and we don't have basements here, most homes are on slabs) and lets say that it's in the first floor bathroom on the other side of a two story house. Like my house.
I have an Assembly Bill 1236, This law requires the enforcement official's supervisor to review and approve (or deny) an inspector's determination when the contractor or his/her agent asserts that the correction results in a cost of 10% or more of the overall cost of the project.
If it's a $5000 bathroom remodel and it costs $500-1000 as mike said, and of course include paint, drywall, acustic ceiling respray and such.
Now I will admit that there are a lot of "if's" in there.
Just FYI this is a state law and will not apply to everyone out there.
Here is another issue the inspector sympathizes with the ec and allows the old 15 A circuit to supply a new receptacle. The home owner is a smart individual; upon resale a Home Inspectors cites the new outlet is not on a 20 A circuit per Code. The inspectors is called along with the inspectors superiors (selectmen in my area) and your job is gone. Some times it?s not all about you :)
I agree its a tough issue however my logic would tell me that the NEC sized the OCP and the ampacity of conductors for a good reason. Thus why #14,#12, and #10 are mandated max OCP of 15, 20, and 30 respectivily. Even though those conductors may be capable of more.
Now if that is the case then why would a fully loaded / overloaded 15 a circuit be less safe than 20 a circuit with %75 load? Nuissance tripping seems to be the worst case. I find it hard to prove a point that the 15a circuit is less safe. If that can be proved then shouldn't the max OCP for #14 be reduced?
I understand that may happen, but why should it have to. Like iwire (Bob) said, give them an inch...
I appreciate all the responses.
