responder1
This goes back to the question yesterday about the alum 60 degree colum. If NC hasnt adopted some of the codes why are AHJ's are inforcing them
no but i asked a 4question yesterday about using the 60 degree colum for alum and someone mentioned that NC will decide on 1-1-09 if they will adoped that code. just like ark faults.
I corrected it for him.
Did you correct the "k" for a "c" (ark)?:grin: (Don't want to sound critical, just have seen some major typos here tonight.)
That is wrong. it is in effect now. http://www.ncdoi.com/OSFM/Engineering/Documents/2008_NC_Electrical_ICC_Print.pdf
The board is supposed to revisit some of the issues including the se in the 60 deg. column.
Yes, that is correct. I hope they do away with se rated at 60 deg.
