101012-1615 EST
drive21968:
Thanks.
What does average peak power mean vs maximum peak power? During the day if there are no clouds or other atmospheric obstructions, then maximum peak power should be about noon in sun time. Sun time is probably displaced from clock time. Is average peak power the average of all of the daily maximum peak powers, or something else? I do not have an Enphase or any manuals on the Enphase.
Whatever average peak power means the ratio you have observed for July is 4.48 KW / 5.04 KW = 0.89 . At the Ypsilanti Food Coop for a previous week, probably means last week, there was a peak power, I believe, of 1.95 KW from a 2.28 KW rated array. This ratio is 0.85 . Good correlation, but may not be significant. Their charts are flaky and I have to guess at what the scales are. Until you have talked with them you do not have any way to make sense of the values, other than qualitative. Their site is
http://solar.ypsi.com/index.php?siteDetails=foodcoop .
Your daily production of 34 KWH provides a ratio of 34/5040 = 0.0067 and extrapolated to a year is 2.46 . This will be very high compared to a full actual year of real data. However, California will be higher than Michigan. For the Ypsi Coop from the July data I get 318/2280 = 0.139 . Extrapolated to a year is 0.139 * 12 = 1.67 . For the actual year from May 2009 thru April 2010 the Ypsi Coop was 1643 KWH / 2280 W = 0.72 . Thus, the yearly value was less than half of the extrapolated value from this July. However, the July 2009 production was about 75 % of this July's output.
I like some of the design philosophy of the Enphase inverter. It is totally potted, it can optimize its output for each panel, if one panel or inverter fails the whole system is not down, information is available from each panel without additional wires (depends upon carrier current signals), inverter power dissipation is distributed, inverter temperatures probably run lower than for single inverters, there should not be much RFI noise propagated on the AC lines from the inverters to the main panel, the dual inverter uses a separate parallel bus for the AC rather than sequentially thru each inverter, and the DC voltage is low to the inverter and this reduces the stress level on components.
A claim is that the Enphase starts producing with less light on the panel and in cold climates this clears the panel of moisture, frost, and snow earlier and therefore more daily production than for central inverters.
Do all of the claims, etc., prove out in practice?
