Cleveland Apprentice
- Cleveland, Oh
Is ENT (smurf tubing) permitted in cold air returns in dwelling units?
You can traverse the joist space- run perpendicular to it but you cannot run parallel to it with ent. You can even traverse the pan joist with nm cable. Sleeve it in emt and then your are good.this would be actual joist space. I will check 300.22, thank you.
