electricalperson
- massachusetts
how many people use smurf tube a lot? i see it all the time at home depot but never really used it too much for other than LV wiring. i would like to try it out someday
I have used it a couple of times, it has its pros and cons. One good thing to know about the stuff is that it is legal to use standard PVC fittings with it. (connectors,couplings,hubs,ect.)
Why don't you ask Randy the Hack aka Fulthrotl about ENT?
i wondered when you'd turn up... can't you stay over in the other thread where
you belong?
UL White Book 2008
ELECTRICAL NONMETALLIC TUBING
(FKHU)
Fittings ? The outside diameters of ENT are such that standard connectors,
couplings and outlet boxes for rigid PVC conduit can be employed for
ENT that is also constructed of PVC.
This can be an advantage if you want to keep your inventory low.Plus ENT fittings can cost ya.
use it often, like it a lot. it's blue. how can you go wrong with blue?
as dan says, you can glue fitting onto it, but it works quite nicely with
the carlon fittings.
home depot is pricey on it. wholesale houses are much better.
I prefer the grey ENT, that way you dont look like a hack that buys their materials at homedepot
The ENT fittings are expensive and don't work as well. Try putting a 3/4" PVC MA on ENT without glue and a pulling it off. Good luck.
