entering top of trough
When entering the top of outside trough is it code to use those plastic washers instead of a hub?
By plastic washers are you referring to the washers on seal tight fittings?
Edit to add: I agree with SEO...Myers hub it and be done with it.
Do you mean "sealing locknuts"....
...instead of a Meyers Hub?
SEO said:
What are those plastic washers? A Myers type hub works well.
Carlon sells sealing washers, they look like the ones that come on some LFMC connectors.
I do agree Myers hubs work fine but so does the sealing washer for 1/20th of the price.
I've never seen one of the lock nuts before, but in a place where rain will cause the same reaction as a solar eclispe used to in the middle ages. I don't see a lot of things that you guys in the east do.:smile:
I know what a sealing locknut is and have used them I just didn't know what a plastic washer was.:smile:
We use sealing locknuts aplenty here in the west too!:D
What do your contractors typically use instead when they enter enclosures above the terminations?
My standard is myers hubs when entering the top. For the sides above terminations, sealing locknuts.
Believe or not its called a fiber bushen area these parts, it's all plastic, and
caps the plastic threads, the POCO lineman made note of it and I installed them accordingly.
