Have an electrician evaluating a pool shock complaint. Measuing 1-5 volts to gound on railings; Checking continuity from the handrail to the EQPB conductor at the pool pump reads 90 ohms. The pool is an older install and my thinking is along the lines of corrision at the hand rail fittings. Is rhat a reasonable possibilityy ? If there bonding did not reach the hand rail originally could you reasonably have a 90 ohm reading ??
(Homeowner reports still getting a shock with the house main "OFF" but there are 500k transmission lines in the vicinity)
