You inspect a job with a 800 amp feeder. The feeder is parallel 250 kcmil Cu in 3 seperate conduits (600 amp calculatd load). In one conduit, a 1/0 Eq Ground is installed {viol 250.122(F) }. The conduits are metallic.
Would you:
accept as is ?
require the one EGC to be removed ?
other ?
Would you:
accept as is ?
other ?
