No. The attempt is to keep everything within step or touch at the same potential. The resistance to earth is not important. If there is voltage flowing in the earth, there may be dangerous voltages between things that are within step or touchBy adding the copper grid under the pool (680.26) the attempt is to give the bonding grid a lower resistance to ground than the human.
Is that correct?
This would not necessarily be zero. If we bonded all the items together and energized all at 120v (just for conversation) on them, it would still be safe since all would be equal.The attempt is to keep everything within step or touch at the same potential.
Exactly what section are you getting this requirement from in the 2005 NEC?Originally posted by hey_poolboy:
The '05 code stipulates that if there is no structural steel in the pool shell itself that a copper grid shall be placed under the pool in addition to the conventional bonding, and I don't understand that.
