Re: equip ground size for 150 hp 480v 3 phase mtr
Try explaining that motor wiring is sized to continuously carry full load while the EGC is sized to safely carry fault current for the short time until the breaker trips.
EGC is also sized to keep the voltage drop due to fault currents flowing in the EGC below harmful levels. Motor conductors are sized to keep voltage drop at full load or during starting within a few %.
Different criteria, different applications on the same motor lead to different wire sizes for EGC and motor conductors.
