i have a meter base and main disconnect in a panel back to back with a distribution panel. the two inch nipple connecting them has bonding bushings on either side. i have screwed down a lug in both panels with a ten thirty two screw and i have a bare number six landing at all four points. does this number six also need to leave either of the panels and go off to one of the the grounding rods ? there is a separate grounding wire also bonded to both panels, one end of which picks up the three pipes at the water heater and the other end of which goes to the two grounding rods placed more than six feet apart . its a two hundred amp set up and the longer wire that goes to the water heater and the rods is a number four. i didnt want to wrangle it through the lugs on the bonding bushings either end of the nipple. seems like i should be able to get away with this. the equipment is all bonded solidly.. what do you think/know? thanks
