shocker3218
I am installing A FIRE PUMP WITH A TRANSFORMER TO STEP UPFROM 208 TO 480 VOLT. sERVICE ENTERS BUILDING VIA A 200 AMP METER SOCKET, THEN HITS A 600 AMP MAIN DISCONNECT FUSED AT 450 AMPS (ALL PER LOCAL CODES AND AHJ) .
MY QUESTION IS, SINCE NEUTRAL IS BONDED AT MAIN DISCONNECT, AND THE LOW VOLTAGE SIDE OF THE STEP UP TRANSFORMER (75 KVA 208Y-480DELTA) AM i REQUIRED TO RUN AN EQUIPMENT GROUND CONDUCTOR? i AM USING 2 FT. OF FLEX FOR FINAL CONNECTION TO TRANSFORMER. ALSO, WHAT ABOUT GROUNDING ELECTRODE CONNECTION FROM TRANSFORMER? WHAT DO I BASE THIS WIRE SIZE ON? 200 AMP SERVICE, OR 450 AMP FUSES?
