We are using 8/2C MC cable for a 120V circuit protected by a 20A breaker. No. 8 is being used to compensate for voltage drop. The factory supplied eq. ground size is No. 10. The manufacturer states that the cable is in compliance with UL 1569 which allows reduced eq. grounds in MC cable. The inspecting authority is challenging the eq. ground size citing NEC 250.122.B as requiring the eq. ground to be increased in size proportional to the ungrounded conductors, therefore the eq. ground should be a No. 8. We disagree. Thoughts?
