equipment ground wire
anbm
TX
Designer
When we do not need to install equipment ground wire in branch circuit and feeder? Is it for residential application only...?
You are required to install an EGC (equipment grounding conductor) with all line voltage circuits. A metallic raceway may be used as an EGC under certain conditions.
