bark
- Washington
Ok, Just a quick question. I'm wiring up a 200 amp disconnect that feeds a 200 amp panel 300 ft away. In the disconnect, the neutral bar is small, with no lugs large enough to accept the #2 equipment grounding conductor. I think I can connect to ground bar I installed, with a correct size lug. I want to get some other opinions. Been awhile since I've done this sort of service.
Thanks
Thanks
