Re: Equipment Grounding Conductor to Motors
To: Jim gerlach, Jim, I have answere this question before in a previous post, but I do not mind giving you my opinion.
Yes, you can relay upon the conduit for your grounding conductor for your motor, that goes back to your MCC. We did this for many years at a Dupont plant. We do not do it today. We carry a grounding conductor inside of the conduit, from the motor back to the MCC. The reason that we changed was for Safety. Many times the coupling on the conduit would become corroded and then you have lost your grounding continuity. Or the conduit becomes broken. Again you have lost your ground. Jim,today I would always carry a ground wire in the conduit for Safety.
regards, bob friebel
