chris huckins
- collinsville,il
In the 2011 NEC Article 250.121 says "An equipment grounding conductor shall not be used as a grounding electrode conductor". I'm thinking about a 480 volt, 3 phase combination motor starter that incorporates a step down, single phase control transformer 480v-120v. A jumper is installed on the secondary side from the grounded terminal (X2) to the case of the motor starter, so does this now violate 250.121 because we are using the equipment grounding conductor,wire, installed with the circuit feeding the motor starter as a grounding electrode conductor?
