equipment grounding conductor
Shockedby277v
Michigan
What size copper equipment grounding conductor is required for a 200 amp 480 volt branch circuit that is fed with 3/0 THW?
Thnx in advance
Re: equipment grounding conductor
250.122
I remember back when I was in school a lot of homework question asked where based on TW copper conductors I guess this was to get us used to checking different columns in the ampacity tables
I am not quit sure why you are installing the 3/0 TW for the 200 amp circuit. What is this circuit being used for?
[ February 19, 2006, 01:45 AM: Message edited by: david ]
Now, now, David... You changed your answer from "250.66"! You aren't allowed to do that with obvious test questions after you click on the submit button :)
