Is there a code reference that either allows or disallows the use of a separate(redundant) equipment grounding conductor on portable cord connected, 3 phase(delta), welders. These machines are sometimes used in a wet environment, and the idea is to protect the persons using these machines in the event that the equipment grounding conductor in the cord is compromised.
These redundant equipment grounds were added to portable cord connected welders after several near misses and one death at a company for which I formerly worked. The rule was that if the external equipment ground was compromised in any way the machine could not be used until the equipment ground in the power cord was proven good and the external ground was repaired. The assured grounding checks were made to the equipment grounding conductor in the cord on a regular basis, as required by OSHA. After these changes were implemented there were no more incidents.
I have found a reference to an external equipment grounding conductor on cord connected equipment that is to be used in wet areas in a DOE electrical safety document, but I don't see where it's specifically referenced in the NEC.
