Smiley64
- Middleton Wisconsin
I am replacing 80 light fixtures on a cement ceiling that has PVC conduit connected to a plastic box then a metal octagon extender over the plastic box to bring it flush with the surface. The extender has an 8-32 tapped hole in the bottom tab. I can't find what size the grounding screw has to be in the NEC. Does it have to be a #10? Does the grounding wire from the extender into the fixture have to be #12 if this is a 20A breaker? (250.122)
