marmathsen
- Seattle, Washington ...ish
- Electrical Contractor
I'm a residential electrician in the Seattle and do a lot of remodels.
One thing I see a lot of is old work where the equipment grounding wires all come into the box with the old NM cable then are routed outside of the box and connected where it's inaccessible if the walls are all closed up. Why was this so common? What the the thinking in doing it this way?
This is almost always where the old cloth Romex with the undersized ground is used. I think typically 1950s or 60s.
Sent from my Pixel XL using Tapatalk
