I am re-wiring an older home and desire to install grounded receptacles where there are currently 2-prong receptacles. There was no equipment grounding conductor run to the boxes. I would date most of he wiring pre 1950. There is some type of armored cable used (no NM).
I would like to know if I can use the armor sheath as an equipment ground. I would also like to know if there are approved clamps available to bond a copper wire to this sheath, so that I can bond it properly on both ends.
