Equipment GroundingConductor
smallfish
Detroit
Does the National Electrical Code 2014 allow the electrical metallic tubing enclosing feeder conductors run from Service disconnect to distribution panel to serve as a means of equipment grounding or must a wire-type equipment grounding conductor be run with the feeder conductors?
Thanks
Yes. Be sure and check out 250.94.
Thanks
No, not required.
