When system's X/R ratio is higher than OCPD's testing X/R ratio, the equipment will face derating on Aic rating. In low voltage system, for example 480/277V with 200kA fault x/r=8, What if your equipment and OCPD is already 200kAic, and you face derating. Due to the derating, your equipment will not have sufficient Aic rating. Then your equipment is not good at this scenario, what will be the solution? I think 200kAic is max Aic rating in the low voltage system.
