robcircuits
Does anyone know the page/ section in the NEC that specifically states the required clear distance between an equipment rack (containing many rack mounted, low voltage, low current audio/ video/ data devices that are all powered by 120VAC from a rack mounted strip) and the wall or nearest surface?
(For instance... does the same distance rule apply as in the case of breaker panels that state 36" clear in required?)
