FREEBALL
- york pa usa
ok so an above ground pool does it require 4 point bonding and do you have to run a perimeter #8 sol around the pool. I say yes it does but inspector said 1 bond to steel is sufficient. I read pool specs for the install im bidding on and it shows 4 clips they call ground clips at 4 points around the pool. The code cycle they are using is 2008, so maybe im off on the requirements. Does anybody have any thoughts. Im bidding as to bond all 4 with the perimeter bond. Now insp. said well you can do that but it isn't enforced. Its difficult to bid a job this way.
