Guys and gals, I've got a strange one that I was hoping to get some input on. We are working on the design of a very large wave pool that is going to have twenty-two 150 horsepower pumps. The pumps are completely submerged in the wave pool and do not have any metallic piping connected to them. For equipotential bonding purposes, the pump manufacturer has designed an exposed connection point on the outside of the submersible pump housing to land a bonding wire on. The manufacturer is also providing a cable whip which includes a grounding conductor for equipment grounding connections.
We initially proposed using insulated #8 solid copper wire and encapsulating the termination in marine-grade epoxy but the contractor believes this may be an installation and maintenance issue and is hoping to just use a bare #8 solid copper wire. However, we believe that bare copper submerged in chlorinated water may cause the wire to deteriorate rapidly, especially if high concentrations of chlorine are used to "shock" the wave pool water.
Does anybody have any trade secrets on how these submerged pumps could be equipotentially bonded?
