Equipotential plane for horse barns
dec
OK... Equipotential bonding per the NEC consistantly mentions concrete surfaces.....but.....what about a dirt floor in a horse stall with a waterer in one corner of the stall? ALSO.... what about an outdoor waterer where horses stand on dirt???? Now what do you do???
You either work very hard to eliminate any voltage offset, whether resulting from leakage or from EGC/remote-ground offset or you install some semblance of an equipotential plane.
So.....if the stalls and corral are all dirt....then I do't see how the equipotential bond will make a difference, considering the mesh would have to be below grade at some depth where horse hooves can't get hung in it when it is muddy. I wonder if a water bond similar to a swimming pool would work ???
No EQ plane is required in areas with dirt floors.
Kinda what I thought because NEC seems to always point to concrete but was hoping someone else has run across this.
I've been hired by farmers to just run #8 through everything possible in the past
yes it helps
however , thinking about equipment layout is a consideration as well
for ex, as i suspect you already know, electric fencers can take advantage of all bondings
so their proximity to say, waterers and feeders , might be an issue
~RJ~
yes it helps
~RJ~
That is almost cruel to place an electric fence near the water or food, at least for horses or cattle. They have a tendency to stay away from the fence in the first place, so you are also forcing them away from the food or water, even if it doesn't introduce other electrical problems.
well i agree kwired, save for it's not always intentional , i mean.....we're talking farm hands.....:) ~RJ~
