ES License
SOSsigns
New member
I have held my ES license for the last 5 years and just recently had a question asked that I wasn't sure of. Of the ES categories (043, 068, 065, 067, 069) is the ES license holder restricted to only one of these categories or can he/she work on each of these categories?
Coppersmith
Tampa, FL, USA
Electrical Contractor
"ES – A “specialty contractor” means a contractor whose scope of practice is limited to a specific segment of electrical or alarm system contracting, including, but not limited to: elevator specialist (class code 066), utility line electrical specialist (class code 068), low voltage system specialist (class code 069), residential electrical contracting (class code 043), maintenance of electrical fixtures (class code 065), and fabrication, erection, installation, and maintenance of electrical advertising signs (class code 067)."
http://www.myfloridalicense.com/DBPR/electrical-contractors/#1489159935794-47166768-3ea7
I believe if you are a sign contractor (code 067) you are limited to doing signs, but you should explore the above site. It should answer all your questions.
