F Fordean Senior Member Location New Jersey Occupation Electrical Contractor Mar 24, 2021 #1 ES Sealing Hubs. For Class two . Shown in attachment. With this type of fitting you do not need a EYS or EYD unless speced. ES fitting Is in Lieu of EYS. Correct? Attachments EGS-AEC501923.pdf 303.3 KB · Views: 11
don_resqcapt19 Moderator Staff member Location Illinois Occupation retired electrician Mar 24, 2021 #2 If you install it per the instructions, you can use that fitting where the code requires a seal fitting.
